Date/Time: Mon, 06 May 2024 05:37:59 +0000
Error message
View Count: 3071
[2013-03-20 12:26:50] |
ZH Support - Posts: 19 |
Just wondering what would activate this error message and what I would need to do to fix it. Event Type: Error Event Source: .NET Runtime Event Category: None Event ID: 1026 Date: 3/19/2013 Time: 1:02:45 PM User: N/A Computer: MAINOFFICE1 Description: Application: SierraChart.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.AccessViolationException Stack: at ._WinMainCRTStartup() For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. Bucket -816526070, bucket table 1, faulting application sierrachart.exe, version 700.0.0.0, stamp 5134f2b9, faulting module tawiretypescpp.dll, version 0.0.0.0, stamp 50994ca2, debug? 0, fault address 0x0000674d. For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. Faulting application sierrachart.exe, version 700.0.0.0, stamp 5134f2b9, faulting module tawiretypescpp.dll, version 0.0.0.0, stamp 50994ca2, debug? 0, fault address 0x0000674d. For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. |
[2013-03-20 16:22:16] |
Please contact Bob at TransAct about this. Notice that it says the faulting module is: tawiretypescpp.dll (a TransAct file) When exactly does this error occur? What specifically are you doing with Sierra Chart before it occurs? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-03-20 16:23:03
