Date/Time: Tue, 07 May 2024 05:24:28 +0000
Price Display format and Tick Size under chart settings
View Count: 914
[2015-10-27 21:02:00] |
ripsdips - Posts: 143 |
Hi. I'm changing the Price Display format and Tick Size under chart settings for SPX500 to where I want it. When I close and save my chart book it doesn't open up as I closed and saved it as, it comers back as default. Any advice on how I can make that stick?
[2015-10-27 21:09:15] |
Make sure you uncheck Chart >> Chart Settings >>Auto Set from Data Feed. As long as that is unchecked, they definitely should not change.
