Date/Time: Mon, 29 Apr 2024 09:01:55 +0000
No soybeans data
View Count: 665
[2015-10-27 15:16:13] |
User31044 - Posts: 33 |
Not getting any soybean (F.US.ZSEF16) data; all other symbols ok. I've tried different months, too, but none have any data: http://www.sierrachart.com/image.php?l=1445958963912.png |
[2015-10-27 17:52:38] |
The prior response was not the correct answer. You need to re-download the data in the chart with Edit >> Delete All Data and Download. If that does not solve the problem let us know. It appears as though there was a failure with downloading data previously. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
