Date/Time: Wed, 08 May 2024 12:37:30 +0000
Volume bar color study
View Count: 1907
[2015-10-27 15:11:37] |
User31044 - Posts: 33 |
Hi I was wondering if there was a way to color the volume bar based on the the close of the price bar as it relates to the midpoint of the price bar (see attached for example - even though the close is greater than the previous close and the current bar open, the close is less than the midpoint of the bar) http://www.sierrachart.com/image.php?l=1445958619128.png |
[2015-10-27 18:47:46] |
User11942 - Posts: 298 |
You can color (or do whatever with) price graph bars instead using Color Bar Based on Alert Condition study. Here is the reference https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 Date Time Of Last Edit: 2015-10-27 18:49:44
[2015-10-27 20:56:27] |
I found the study I was needing in 'Sierra Chart Custom Studies and Examples (SierraChartStudies.dll v1311)' > 'Volume - Close To Midpoint Colored'. Where can I access the source code for all of the studies in SC? I'm about to take a programming class and would like to look at the coding used for studies. |
[2015-10-28 04:06:26] |
The source code is in the /ACS_Source folder. Refer to this page for more information: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
