Date/Time: Mon, 29 Apr 2024 14:14:00 +0000
Incorrect Start Day on Weekly
View Count: 838
[2015-10-26 22:11:28] |
conr - Posts: 204 |
Started Sierra this morning and my 7 day chart started on 10/20 instead of today. Next bar starts tom. I reloaded several times.
[2015-10-27 01:14:07] |
Yes, this is expected unless the chart starts on a Sunday or Monday. Refer to the documentation for this here: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TimePeriodPerBar Specifically the section for creating Weekly bars from Intraday data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-27 01:14:38
[2015-10-27 13:56:51] |
conr - Posts: 204 |
I know what happened. I ran out of history. So you and others know the chart will default to a tuesday if you are at a 7 day setting and a historical monday date. I had my 'use date range' set at 2010-7-10.
