Date/Time: Tue, 07 May 2024 20:41:46 +0000
Help w/ formula and placement of formula
View Count: 700
[2015-10-26 22:46:50] |
Sawtooth - Posts: 3993 |
The latest price is in E3. If your signals are at close of bar, use E4. Try something like this in J26: =FLOOR(1000/E3) This will round down to the nearest integer. |
[2015-10-27 01:17:55] |
It sounds like you want to use the Order Quantity cell which is documented here: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#CellJ26 You will have to work out the formula on your own to set the quantity. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-29 01:40:36] |
This: =AND(O11981,Q11981,S11981,U11981,W11981,AA11981,AC11981,AE11981,TRUE, FALSE) Needs to be changed to: =AND(O11981,Q11981,S11981,U11981,W11981,AA11981,AC11981,AE11981) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
