Date/Time: Tue, 30 Apr 2024 13:38:01 +0000
How to set tick size for USDJPY
View Count: 948
[2015-10-21 16:17:03] |
User76939 - Posts: 11 |
I would like to trade USDJPY with SierraCharts using FXCM data feed. What is the property tick size that I should use to achieve the 2 decimal pip value? In the Chart Trade window, the P/L unit s 0.00C. How do I convert unit "C" to unit "pip"? Thanks. |
[2015-10-21 17:48:25] |
The tick size is already set to .005 in Chart >> Chart Settings. That can be changed. Here is the documentation for it: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TickSize Be sure to refer to the documentation to know what you are doing. For the other question, refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/helpdetails77.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
