Date/Time: Mon, 29 Apr 2024 01:01:47 +0000
sc.TicksToPriceValue
View Count: 705
[2015-10-21 14:57:15] |
CMG - Posts: 179 |
Hello, What is exactly this function for, it does not have a description on the documentation. Thanks as always #girlswhocode PV |
[2015-10-21 15:27:52] |
DarthSidious - Posts: 63 |
Yes, but from sierrachart.h: float TicksToPriceValue(unsigned int Ticks)
And TickSize is defined here{ return Ticks*TickSize; } http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scTickSize So TicksToPriceValue() will tell you the total value of that many ticks for the current chart |
[2015-10-21 15:32:10] |
CMG - Posts: 179 |
I am debugging someone else's program and they use this function as a means to get the arrow closer to the candlestick/bar chart, is it a correct use of the function. It seems to work however the arrow it is not on top of the bar but a little away. Patricia |
[2015-10-21 15:53:57] |
SC has a built in study: "Swing High And Low". Try it and see how you like it in terms of arrow placement. Then, find the code in sierrachart/acs_source/studies6.cpp. It uses a % based arrow offset. You can instead use TickSize.
[2015-10-21 15:57:24] |
This is all it does: float TicksToPriceValue(unsigned int Ticks)
{ return Ticks*TickSize; } So it takes a number of ticks, multiplies it by the Tick Size and returns the actual price value. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-21 15:58:20
