Date/Time: Tue, 07 May 2024 20:29:47 +0000
Multi-time frame trendlines don't match
View Count: 872
[2015-10-21 14:28:13] |
User49270 - Posts: 48 |
Hi, I'm using a 60 minute chart as my anchor chart and copying trendlines to a 4 range chart with the Copy Chart Drawings set . The trendlines don't match, I'll get a trendline break or touch on the 60 minute chart but it won't be at the same price on the 4 range chart. Thanks
[2015-10-21 16:16:25] |
It is not possible for there to be an exact match. Refer to the documentation about this here: https://www.sierrachart.com/index.php?page=doc/helpdetails34.html#ChartDrawingMapping We cannot provide any further help with this other than what the documentation already says. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
