Date/Time: Fri, 03 May 2024 20:18:09 +0000
Candlesticks are slow to update intraday
View Count: 760
[2015-10-21 14:17:24] |
User795833 - Posts: 15 |
This problem just started a couple of days ago. The candlesticks on my charts are lagging on updating data. I can see the price moving very fast on the right axis, but the candlesticks don't move along with it. How can I fix this problem?? |
[2015-10-21 16:17:39] |
If you do not want this behavior you must disable the True Real-time data for Intraday charts option: https://www.sierrachart.com/index.php?page=doc/IB.php#TrueRealTimeData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-21 16:39:19] |
That solved the problem thanks, I don't like the fact that now I have less accurate data though.
