Date/Time: Fri, 03 May 2024 19:27:27 +0000
value chart
View Count: 703
[2015-10-19 18:04:54] |
User174857 - Posts: 11 |
trying to make the OHLC bar thicker on the value chart study.. change the width to all 3's and will not apply it.. will allow it on candle bars but not on OHLC bars |
[2015-10-20 04:18:35] |
You need to change the bar widths through the Graphics Settings window: http://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
