Date/Time: Sat, 27 Apr 2024 12:56:50 +0000
Study/Price Overlay study
View Count: 719
[2015-10-19 15:58:13] |
trader1 - Posts: 128 |
Hi, I have one stock chart for symbol AAPL overlayed on another stock chart. On the subgraphs section I have "show" checked under "Value Label". The problem I am having is that the value shown for symbol AAPL on the overlayed chart is different than the value shown for symbol AAPL on the original chart. Can you please tell me how to correct this? I have read the help section http://www.sierrachart.com/index.php?page=doc/helpdetails28.html#UsingtheStudyPriceOverlayStudy Thanks. |
[2015-10-19 18:16:12] |
For what Study Subgraph did you enable the Value Label for? Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-19 19:24:58] |
I think it was the wrong one. Let me adjust it and see if that solves the problem. Thanks. |
[2015-10-19 19:28:18] |
Yes. Most likely that was it.
