Date/Time: Sat, 18 May 2024 23:12:25 +0000
Volume by Price not referencing the right time back.
View Count: 1052
[2015-10-19 14:59:26] |
User866531 - Posts: 14 |
Hi, Trying to get the VbP to work and can't figure it out. I've read through the documentation 4 times (https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php) I have data set to Tick. I'm trying to get it to reference the last cash session only with no volume referenced from the rest of the day. Today, the VbP VAH/VAL/POC are all plotted below the low of the last cash session but it is clearly within the overnight range leading into today. Here is the settings - https://gyazo.com/75fb799ef817a66b31b66fe9db573ebb https://gyazo.com/ebbe07758265c854d9577f12768a20d9 https://gyazo.com/45c0e4afa3aa29623320c7a19bcdf0aa I have the hours set that I want it to reference to plot the VbP Value lines from but it seems to be referencing the hours outside of these only. I'm sure this is something easy I have over looked but it is driving me up the wall as I can't figure out what exactly the cause is. I'm still trying to get used to SC, sorry if this is some obvious thing I've overlooked. Attached is a picture of the chart and I've highlighted the areas where it should be getting the data from and also where it seems to be getting it from instead. |
VbP periods back.png / V - Attached On 2015-10-19 14:51:55 UTC - Size: 21.03 KB - 296 views Attachment Deleted. |
[2015-10-19 15:02:57] |
Sorry, all good now. Just fixed it. Reversed the times to everything outside the cash session and it plots fine now. |
[2015-10-19 18:23:48] |
If you want to have the Volume Profiles to be based upon a specific period of time you need to set that time range in the Session Times and not include any other times: https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php Or you need to set the Volume Graph Period Type to Multiple Profiles from Start Time to End Time and set these times within the Volume by Price study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
