Date/Time: Sun, 05 May 2024 13:43:20 +0000
Toolbar settings
View Count: 1617
[2013-06-18 14:07:19] |
User59482 - Posts: 14 |
I have just done the latest update and I lost my custom toolbar settings. Am I able to retrieve them?
[2013-06-18 16:20:14] |
Are you saying that the buttons on the Toolbars are different?
[2013-06-18 16:45:21] |
TechTrader - Posts: 116 |
This happened with my toolbar settings, updating from somewhere between SC984 to SC988. The chart bar custom period settings changed from volume to time periods. I reset them to my preference and updating to SC989 showed no problem re. toolbar. |
[2013-06-18 17:58:09] |
I had a few different custom time periods in toolbar 1. Now it has some of them but not all of them and they are not in the order I had them. Now from left to right, the time periods are daily, weekly, 3h, 2h, 1m, 89m, 5m, 3m, 34m, 1m, 10m, 30m, 21s, 4h. I had them all in a sequence from left to right , shorter to longer and some different time periods than are there now. I looked in the other toolbars , but they are not there. I did not have 10m, 30m, 3h, 2h, in the toolbar at all? I can re enter everything again but just wondering if they are stored somewhere else, or just lost? I had a 13 second time period, and can't find it anywhere, as for most of the others, they are still in the available toolbar commands. |
[2013-06-18 19:51:46] |
We are looking into this. Something has gone wrong when we added the Flex Renko Bar Period Type for Custom ToolBar buttons.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-18 19:54:52
[2013-06-18 21:15:53] |
We are going to put out a new release later today which will resolve this. Please just leave the custom chart bar period ToolBar buttons as they are and they will be restored.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-18 21:16:12
