Date/Time: Sun, 05 May 2024 22:24:28 +0000
Sum all Charts from List: don't work
View Count: 854
[2015-10-19 10:08:07] |
User11527 - Posts: 10 |
Hello, I try to use the study "Sum Charts from List": No result appears on the chart. However, the study "Sum all Charts" works correctly (and even give bars if I choose the corresponding settings !). I join the chartbook that i work. Thanks |
Private File |
[2015-10-20 04:14:55] |
We cannot accept your Chartbook. There is too much complexity with it. Here is the documentation for the study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s228 If you are providing a Chartbook, it must be a very simple Chartbook consisting of nothing more than 2 charts and the one study in question and no unusual settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-20 04:17:27] |
Although we do now realize what the problem is. In the list of chart numbers specified with the study Input you are using the #. You cannot use the #. Remove that. For example use: 1, 2, 3. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
