Date/Time: Thu, 02 May 2024 15:44:44 +0000
SC build upgrades do not preserve default *.twconfig files
View Count: 732
[2015-10-19 08:22:38] |
i960 - Posts: 360 |
If one saves settings for something like SimpleBracket.twconfig, they'll be overwritten on a build update. That's the main issue. Additionally, where exactly are per-chart configs for this being stored? In the chartbook? If one updates the default settings it can be extremely tedious to update the associated twconfig for each chart everywhere. |
[2015-10-19 09:21:21] |
We will not overwrite these files if they exist. The Trade Window configuration is stored in the Chartbook file. You should also be aware that Trade Window linking is now supported through the standard Chart Linking feature. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-19 20:15:26] |
i960 - Posts: 360 |
Well I'm saying they've been getting overwritten. This is the second time now I've saved different settings to SimpleBracket.twconfig only to find they've been reverted and the file timestamped the exact same as the other default twconfig files.
[2015-10-19 21:06:10] |
What we meant is we made a change where they will not be overwritten when updating Sierra Chart.
