Date/Time: Sun, 05 May 2024 09:03:50 +0000
Numbers bar error
View Count: 1083
[2015-10-17 17:14:07] |
User186005 - Posts: 3 |
Hello With numbers bars, the top and the bottom of the candle doesnt finish in 0 ( 0x4; 0x14). And I dont know why, I dont know if is a problem of my data feed. thanks Date Time Of Last Edit: 2015-10-17 17:17:19
2015-10-17_1910.png / V - Attached On 2015-10-17 17:16:47 UTC - Size: 46.72 KB - 332 views |
[2015-10-17 21:27:21] |
User167108 - Posts: 49 |
what chart settings you are using
[2015-10-17 21:32:00] |
5 minutes, and its the same with reversal and number of ticks
[2015-10-17 21:47:32] |
Technically it doesn't have to be 0X4 or 0x1 at the end of bar .. It means auction is unfinished at that point and new bar starts based on our settings.. I could be wrong
[2015-10-17 22:35:51] |
What we see is normal and correct.
[2015-10-21 10:09:02] |
Sorry, but 45x65 instead 0x65, means unfinished aution and that means that the market has to return to fill all those contracts, and its not possible in that case because everything is an unfinished auction. I dont know why this happens, but with ninjatrader indis we dont have this values
[2015-10-21 10:15:20] |
Unfinished for the time period based on your chart .. If you change time period , it might look finished auction . Accuracy of data vs Ninja , i am not sure ..
[2015-10-21 17:43:44] |
Make sure you have a tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php If you do, the data you are seeing is correct and you should trust that it is correct. That you can count on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
