Date/Time: Thu, 02 May 2024 08:34:46 +0000
cannot find hong kong stock data in teletrader data order form
View Count: 1295
[2015-10-16 17:00:22] |
User385518 - Posts: 9 |
The website of teletrader lists Hong Kong stocks market as one of the many market data provided. However, I cannot find the Hong Kong stock column on its order form. http://technologies.teletrader.com/Financial-Services/TeleTrader-Data-Universe-%281%29/Cash-Markets---Indices.aspx https://proweb.ttweb.net/catalog/step1.aspx So, How can I get the Hong Kong stock exchange data? |
[2015-10-16 17:38:59] |
We need to ask them about this.
[2015-10-17 00:55:12] |
Thanks, wait for your reply.
[2015-10-17 01:08:49] |
We will post the response here from TeleTrader when it is received.
[2015-10-19 08:04:17] |
TeleTrader has informed us that they no longer support the Hong Kong stock exchange.
[2015-10-20 10:36:03] |
Thanks for your reply. I would suggest that sierra adds a data provider who can provide Hong Kong stock data and Hang Seng index futures data.
[2015-10-20 10:37:27] |
Our suggestion is that if you know of one, let us know and we will encourage them to adopt the DTC Protocol: http://dtcprotocol.org/ Sierra Chart supports the DTC Protocol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
