Date/Time: Sun, 05 May 2024 17:12:23 +0000
SC Volume by price gives different results from other trading platforms.
View Count: 2350
[2015-11-02 07:54:38] |
Yes actually that is true and that is a detail we overlooked. The problem is you are on Sierra Chart service package 3. You will need to contact your broker and have them put you on service package 5. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-02 15:47:22] |
User503358 - Posts: 50 |
Finally, everything is working fine? last question: It is possible to highlight by color volume that exceed predifined value in Volume by price indicator? |
[2015-11-02 19:14:54] |
Yes we can see you are on service package 5 now. You just need to re-download the data in the chart with Edit >>Delete All Data and Download. Volume bars in the Volume by Price study can be colored based on percentages. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-02 19:37:45] |
and on value?
[2015-11-08 22:27:00] |
I find out, that identical is only volumes from last (dec15) contract. Other past contracts have differences. You know why?
[2015-11-09 09:13:40] |
We had a look at this. And historical tick by tick data is supported for historical data downloading for expired futures contracts as well. Follow the instructions here to re-download the data assuming the chart is a Continuous Futures Contract chart: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-09 09:14:08
