Date/Time: Mon, 20 May 2024 21:13:42 +0000
Connecting to MS Access Database
View Count: 822
[2015-10-15 03:21:31] |
RitikaGupta - Posts: 7 |
Team, 1) Is it possible to connect sierraCharts to a MS Access Database to read the data? 2) if yes then how? |
[2015-10-15 03:38:35] |
No, this is not directly supported. However, Sierra Chart does support a DTC Protocol client: https://www.sierrachart.com/index.php?page=doc/doc_DTC_TestClient.php Also refer to this page here: https://www.sierrachart.com/index.php?page=doc/doc_IntradayDataFileFormat.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
