Date/Time: Sun, 28 Apr 2024 13:40:07 +0000
New Market Symbols on ASX and Eurex
View Count: 1081
[2015-10-13 11:52:08] |
Acro - Posts: 436 |
Hi, I note that there are two new symbols coming into play this month. 1. Mini SPI 200 on ASX. http://www.asx.com.au/communications/notices/2015/1032.15.09.a.pdf 2. Mini DAX on Eurex https://www.eurexchange.com/blob/1976326/c5edab214f2feed8f74dc297b406c5a9/data/er15173e.pdf Will both of these be available via the AMP CQG data feed please ? I think they are likely to be popular products |
[2015-10-14 04:56:05] |
Yes they will be. Refer to this section here about CQG symbols: CQG Trading Platform Service: CQG Symbol Format You just will need to manually enter the symbols. Also make sure you are on the latest version of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-27 09:58:40] |
tobi - Posts: 351 |
Will these, especially the Mini Dax also be available with SC Chart Real-Time and Historical Exchange Data Feed (with Eurex Exchange)?
[2015-10-29 19:10:11] |
Yes and this has been added.
