Date/Time: Sat, 18 May 2024 21:55:46 +0000
Trade DOM - Bid / Ask Volume does not fit into the grid lines
View Count: 973
[2015-10-13 07:47:46] |
Futurestrader77 - Posts: 126 |
With the new versions the bid and ask volume does overtop the grid lines in the DOM. Perhaps you could take a look into that? Thank you!
[2015-10-13 09:33:37] |
We will check on this. It relates to changes that were done recently to the horizontal grid. It has to do with the horizontal grid alignment relative to the displayed values.
