Date/Time: Fri, 03 May 2024 09:50:25 +0000
trendlines
View Count: 922
[2015-10-12 18:07:34] |
User20450 - Posts: 330 |
everytime i draw a trendline on a tick chart , when i come back to it , the trendline has moved any fix for this ? |
[2015-10-20 12:53:34] |
please advise , this seems to be a on going issue , thanks
[2015-10-20 17:52:13] |
Refer to this Help Topic: https://www.sierrachart.com/index.php?page=doc/helpdetails34.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-20 17:52:29
[2015-10-20 18:12:11] |
so there is nothing u can do about this ? i have never heard of such a thing , no other platform has this issue why would it be any different , ? im not changing the time or chart im simple coming back to same chart to find the trendline ( not ray ) about 1/4" off from where i placed it , that seems a little off for a trading platform ? |
[2015-10-20 18:15:07] |
here is gold chart at 2:12 today , i swtich over to my other charts and came back to same chart at 2:14 and look how off the trendline is , this is normal ?
2015-10-20_14-13.jpg / V - Attached On 2015-10-20 18:14:47 UTC - Size: 30.98 KB - 375 views 2015-10-20_14-13(2).jpg / V - Attached On 2015-10-20 18:14:51 UTC - Size: 30.09 KB - 359 views Attachment Deleted. |
[2015-10-20 18:50:02] |
It is not up to us to do something about this. It is up to you to understand why you see what you do and take the corrective steps. The help topic provides all of the information you need. Please review it again. Are the chart bars not based upon a fixed amount of time? Is the line you are drawing ending in the right side fill space? Yes, it is normal if those chart bars are not based upon a fixed amount of time and being that Line does end in the right side fill space. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-21 01:53:12
[2015-10-20 19:36:59] |
Not arguing with you , The chart is a 5 min chart and no the line is not in the right side fill space |
[2015-10-20 20:08:00] |
Should not be a problem with this, if it is a 5 minute bar chart. Provide an image of the chart by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
