Date/Time: Sat, 18 May 2024 18:05:15 +0000
Chart Graphic Settings
View Count: 750
[2015-10-11 01:01:32] |
User94740 - Posts: 333 |
Hi SC, I am running the latest version 1307 and I have noticed the bar high-low down and up settings fail to work. The box for global graphic settings is empty. Please advise.
Date Time Of Last Edit: 2015-10-11 02:24:07
[2015-10-13 03:57:17] |
You need to refer to the documentation on this page for the color settings for those to understand under what conditions they are used: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-13 10:19:49] |
a setting in the global settings has to be clicked off. thx!
