Date/Time: Sat, 18 May 2024 05:12:14 +0000
Buy depth column not aligned to price
View Count: 611
[2015-10-09 23:50:50] |
User417540 - Posts: 13 |
Hi. Buy and Sell columns seem not aligned to price.Have tried reloading data but still as is: http://www.sierrachart.com/image.php?l=1444380205470.png |
[2015-10-10 19:01:38] |
We are not completely clear what you are making reference to. However, if you are referring to the market depth quantities, select File >> Disconnect and File >> Connect to Data Feed to reset the state and get fresh market depth snapshot data from the server. If you notice the market depth data is not correct, then it is going to be a server-side issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
