Date/Time: Sat, 18 May 2024 06:02:36 +0000
Custom Study and live feeding
View Count: 800
[2015-10-09 17:25:12] |
bskogz12 - Posts: 36 |
This might be a quick fix I have several custom studies I run, when the we live feed it seems to come up with slightly different results than when we load/reset a chart. For instance on one study I separate both up/down bars, when live feeding it simply runs the bar as if it is both up or down. Is there a way that I can have each bar re-evaluated after each close, like with alerts? |
[2015-10-09 18:25:34] |
What you describe indicates a programming error within the custom study which must be solved.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-09 18:26:05
[2015-10-09 18:37:08] |
do you have any idea where I need to look.
[2015-10-09 19:24:02] |
No we do not. This is your responsibility to make the determination. This page may be helpful: https://www.sierrachart.com/index.php?page=doc/doc_ACS_ArraysAndLooping.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
