Date/Time: Sun, 26 May 2024 02:26:54 +0000
Volume By Price
View Count: 820
[2015-10-08 15:04:22] |
QnReally - Posts: 181 |
I am using v.1306 and I think I may have found a problem with the VBP study. I am using Draw Volume Profile to draw a profile on the chart. The VBP is set to show Total Volume - POC Only number. When I first draw the profile that number shows correctly. However, if I subsequently use the right edge of the enclosing outline and drag it with the mouse either to decrease or increase the size by a few bars, the POC volume displayed gets bigger by the POC volume each time. Please let me know if you are able to reproduce it. Thanks. |
[2015-10-09 20:25:16] |
We will be checking on this today.
[2015-10-13 02:30:35] |
This will be solved in the next release.
