Date/Time: Sat, 18 May 2024 08:16:38 +0000
Updated DTC CSharp Client
View Count: 1111
[2015-10-08 12:55:03] |
User436004 - Posts: 7 |
I have started working with the code from https://github.com/SierraChart/CSharp-DTC-client and noticed that it has not been updated in 2 years and is currently on DTC protocol 3 while SC is using protocol 7. Do you know of a DTC CSharp client that is at protocol 7 or at least newer then 2 years old? |
[2015-10-08 16:43:48] |
No, this does not exist. Have a look at using the Google Protocol Buffer encoding instead. We assume Google does have libraries for C#. Refer to DTCProtocol.org for more information. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-08 16:44:59
[2015-10-10 04:12:47] |
Here is the documentation for Google Protocol Buffers: https://developers.google.com/protocol-buffers/?hl=en C# is supported. Google Protocol Buffers is a supported encoding for the DTC Protocol. And here is the information about Google Protocol Buffer support in the DTC Protocol: http://dtcprotocol.org/#GoogleProtocolBuffers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-10 04:13:34
