Date/Time: Sun, 19 May 2024 02:58:33 +0000
Problem with Add Sheet to a existing spreadsheet from the Spreadsheet menu
View Count: 691
[2015-10-07 04:43:28] |
User941434 - Posts: 39 |
When I ave a chart open with a "Spreadsheet for Trading" Spreadsheet and i select Add Sheet in the spreadsheet menu nothing happens? The Add Sheet is not grayed out and appears to flash, but a second sheet is not added to my sole existing open Spreadsheet for trading?
[2015-10-07 06:48:54] |
We do see this problem. It must be a new problem because this was not the case before. We are checking on it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
