Date/Time: Sat, 18 May 2024 22:04:00 +0000
change account & ATM on all open charts & DOMS
View Count: 886
[2015-10-07 00:53:51] |
User742717 Mike - Posts: 86 |
Hi, I have a 6 charts & 6 doms, I trade on both, 6 symbols, plus an anchor timeframe per symbol. It takes some time to change them all switching accounts and/or ATM. Would be nice if there was a process which could assign the same account and/or ATM. Optionally, limited to a chart book. Date Time Of Last Edit: 2015-10-07 01:09:21
[2015-10-07 03:37:06] |
This can be done with Trade Window linking. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChartLinking Also be aware we are not accepting new suggestions at this time: Notice: Suggestions (Currently not accepting) It is outside of our support and abilities to be able to keep up with these. We have seen several from you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-07 03:37:17
[2015-10-07 04:15:46] |
Thanks the ATM works, but account changing does not. And there is no mention of account changing in the document nor on Chart settings. |
[2015-10-07 04:37:10] |
We will check on this. We do see a problem with the trade account not changing on linked Trade Windows.
[2015-10-09 00:16:54] |
Hi guys, thanks for the update. Sorry to be a pain, but is doesn't work on sim? which is where I use it mostly to do testing for different strats etc. Hope you guys can fix it. Thanks again. Mike. |
[2015-10-09 00:34:39] |
The What is New page indicates that Trade Window >> Trade Account linking has been released but actually it has not yet been after we tested it on the code base which was released. It will be out in the next release. We apologize for the mistake. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-09 00:35:32
