Date/Time: Sat, 18 May 2024 09:05:17 +0000
Double Click To Adjust Drawing...
View Count: 1160
[2015-10-06 00:38:10] |
boogybren - Posts: 9 |
When you have two drawings close to each other and you double click on one to adjust it, sometimes it selects both drawings and labels them 0, 1 etc... Is there a way to select drawing 0 for example when it gets into this state as to suggest to the program that is the drawing you wish to adjust? Brenden |
drawing.adjustment.png / V - Attached On 2015-10-06 00:37:52 UTC - Size: 32.2 KB - 296 views |
[2015-10-06 03:55:04] |
Refer to the documentation here about this: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#AdjustChartDrawing Refer to the subsection about converging drawings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
