Date/Time: Sat, 18 May 2024 12:40:15 +0000
User Questions
View Count: 757
[2015-10-05 15:43:20] |
Sierra Chart - Max - Posts: 5618 |
Hello support,
i have a problem with the last bar with a "Bid Ask Volume Ratio " indicator , for exemple. When i watch that indicator the last bar continue to move until the new bar borns. I would like to evade the last bar, so i have not more that bothersome movement. how can i do ? Sierra Chart Support Date Time Of Last Edit: 2015-10-05 15:43:34
[2015-10-05 17:46:25] |
This is not supported in Sierra Chart.
[2015-10-05 19:44:10] |
Sawtooth - Posts: 4000 |
You can do this with the Spreadsheet Study study. Here are the steps: 1) Hide the Bid Ask Volume Ratio study, and move it to the top of the Studies to Graph list. 2) Add the Spreadsheet Study study, set the Chart Region to the same as the Bid Ask Volume Ratio study, give it a name in the Spreadsheet Name field. 3) On the spreadsheet, put this in cell K3: =IF(ROW()=3,0,AA3) put this in cell L3: =0.000000000001 |
