Date/Time: Sat, 18 May 2024 11:36:53 +0000
How to load a template given from another user
View Count: 2283
[2015-10-05 08:54:52] |
Jack - Posts: 4 |
Hi, I'm trying to load a template file in sierra charts but I can not find directions on how to do this. All I can find are directions for duplicating a chart, but I have not created the chart to duplicate. Thanks, Jack |
[2015-10-05 18:42:11] |
This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_DLLUsage.html Or refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html We are not certain what you mean by "template". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-05 18:43:27
[2015-10-05 20:49:45] |
Jack - Posts: 4 |
There is a file that was given to me for sierra charts with the file name .tpl When I refer to a template I am referring to the chart settings and study settings saved as one file. Thanks, Jack |
[2015-10-06 03:08:49] |
If the file extension is TPL, it is not compatible with Sierra Chart. It sounds like you might be referring to a Chartbook file. Here is the documentation for sharing and using a Chartbook you have been given: http://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#CopyChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
