Date/Time: Sun, 05 May 2024 03:52:42 +0000
How to increase the upper and lower margins of a chart?
View Count: 1859
[2013-06-17 16:08:14] |
User30668 - Posts: 108 |
Hello, I would like to increase the upper and lower margins of a chart in order to be able to see the support / resistance marked lines – or indicators - with some anticipation. I have been trying to do it but I couldn't figure out how. Is it possible to do that with Sierra Chart? If so, how can I do that? Thanks in advance. |
[2013-06-17 18:05:18] |
M5amhan - Posts: 468 |
there is a user contributed study under the "add custom study" button called "Screen Padder" .. this is good assuming you use an automatic scale setting you can also use a constant range scale (instead of automatic) and use the value scale to set the range |
[2013-06-17 18:38:16] |
Trade2day1, Thank you for your reply. I would prefer some setting like a percentage of the chart but the "Screen Padder" will do it too. Thanks. |
[2013-06-17 18:41:48] |
i believe you can set a number of ticks for the upper and lower padding in the settings
[2013-06-17 18:45:28] |
Yes, I have already done it. Thanks again. |
[2013-06-17 18:48:12] |
You need to use the Interactive Scale Range feature in Sierra Chart. This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#InteractiveScaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
