Date/Time: Sun, 19 May 2024 13:24:32 +0000
Uncorrect Vpb monthly displayed into a weekly chart
View Count: 803
[2015-10-02 08:20:07] |
sierra28 - Posts: 120 |
Problem with stard and end date of a monthly VPB studie applied into a weekly candelstick period chart. cf capture: candelsticks are weekly with weekly vpb (poc in blue):ok. VPB monthly (poc in pink) on the right :uncorrect : A new one should have started two days ago. i have try differents parameters but unable to start a new vpb monthly at the beginning of each month with a weekly period chart. note that vpb monthly are correct if applied into a dayli or monthly period chart. |
weekly period candelstick.JPG / V - Attached On 2015-10-02 08:18:53 UTC - Size: 187.63 KB - 223 views vpb monthly parameters.JPG / V - Attached On 2015-10-02 08:19:08 UTC - Size: 215.8 KB - 246 views |
[2015-10-02 17:14:06] |
The basic problem is you are not creating Weekly bars correctly from Intraday data. How to do this is explained here: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#DaysMinutesSeconds It is necessary to set a From date which begins on a Sunday. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-07 12:32:45] |
hello, problem has reappeared, the vbp monthly display in a weekly chart has incorrect date start. the start date of the week chart begins on a sunday as you ask me to set. in blue vpb Week in pink vpb Month Date Time Of Last Edit: 2016-11-07 15:52:08
incorrect vpb M start date.PNG / V - Attached On 2016-11-07 12:32:42 UTC - Size: 138.77 KB - 175 views |
[2016-11-07 17:11:42] |
There are two problems here. We are not going to review, what you posted previously. This is out of the question. You need to restate the problem as simply as possible as it currently exists. And you did not post an image following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
