Date/Time: Thu, 02 May 2024 17:30:02 +0000
Display text on a chart
View Count: 1635
[2015-10-01 22:47:16] |
Sawtooth - Posts: 3990 |
Set the 'Subgraph Columns Back' to 1
[2015-10-02 03:58:39] |
Use the Text Display for Study study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s334 You will need to add 2 instances of the study. One to reference the High and one to reference the Low of the main price graph. Set the Subgraph Columns Back Input to 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-13 15:50:33] |
User99934 - Posts: 227 |
Is there a way to display the high and low of every bar in the subgraph study using this or another study?
[2018-09-14 01:51:35] |
The closest that is available is this: Study Subgraph Above/Below Bar as Text Otherwise, you have to create your own custom study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-14 15:22:23] |
With a lot of fine tuning, I got the highs and lows set for each subgraph. Unfortunately, when the volatility changes, adjustment will be needed. Wouldn't it be easy to have stationary high/low labels in a subgraph and allow the bars/indicators operate with automatic scaling between the fixed labels?
[2018-09-14 18:39:01] |
You can certainly modify the study to meet your requirements. Refer to: http://www.sierrachart.com/index.php?page=doc/HowToBuildAnAdvancedCustomStudyFromSourceCode.html This will be the best thing to do rather than relying on us because this is not something we can get to. For reference have a look at the Bar Numbering study. And you will want to use an Independent scale for the study . Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-14 18:39:44
