Date/Time: Sat, 18 May 2024 06:22:24 +0000
Cell Question
View Count: 646
[2015-10-01 14:26:10] |
Richard Reyes - Posts: 98 |
Cell "I29" relates to Flatten and Cancel an order or orders with the code to be written in cell "J29". Can I copy I29 to, lets say cell I179, with corresponding code to be written in cell J179? Will this work? Many Thanks
[2015-10-01 14:58:58] |
Sawtooth - Posts: 4000 |
No, but you can either copy I29 to I179, or put =I29 in I179, and put =J179 in J29 and then put your formula in J179.
[2015-10-01 17:36:55] |
You need to do it as explained in post #2.
