Date/Time: Sat, 18 May 2024 07:25:23 +0000
Percentage change since last Close (not Open)
View Count: 933
[2015-10-01 08:21:35] |
User10875 - Posts: 42 |
Hello, for extrating the percentage change since last close I am currently using the Period OHLC Variable Period Study in combination with mulitple other studies (Study Subgraph Divide / Subtract / Multiply ) Is there a more simple way to show the percentage change since last close than using this workaround? Kind regards Sh. |
[2015-10-01 10:03:43] |
This study will be added to the next release: Percent Change Since Previous Close Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-01 10:24:48] |
Nice. Thanks.
[2015-10-01 20:23:45] |
Cavalry3162 - Posts: 523 |
that sound awesome!
