Date/Time: Sun, 19 May 2024 00:53:33 +0000
defining session time for futures
View Count: 993
[2015-10-01 03:06:11] |
dominikos - Posts: 106 |
Can you please validate how I have setup session times for QM futures contract? I turned off "Use Evening Session" and specified start time at 16:45:00 and end time at 16:00:00. I'm located in CST, same as CME. I have load weekend data checked. This should cover both weekday and Sunday sessions. Is this correct or it is safer to include your default 00:00:00 - 23:59:59 settings? Also, I don't have "New Bar at session start" checked, since I prefer my contracts to continue. |
[2015-10-01 03:42:57] |
The way you have set this sounds fine. To be on the safe side set the End Time to 16:44:59.
