Date/Time: Sun, 19 May 2024 00:37:55 +0000
Study
View Count: 676
[2015-09-30 18:24:18] |
User788311 - Posts: 29 |
Hello, I would like to highlight a point which is in a half of a distance between high and low of a bar. Would you help how to create it? Regards, Richard |
[2015-09-30 18:43:21] |
Use the Study Subgraphs Average study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s164 It needs to reference the High and Low price bar data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
