Date/Time: Sun, 19 May 2024 06:58:51 +0000
No trade entry despite "TRUE" entry signal in spreadsheet
View Count: 712
[2015-09-29 16:43:53] |
User73779 - Posts: 2 |
I created a strategy in a spreadsheet, but when the the entry columns flag "TRUE" the sofware won't enter: - I have the order quantity set to 1 - I have "connect to trade service" set to "Yes" - I have Auto Trading Enabled checked Is there some other option I'm not considering? This was working fine a few days ago. Can you help me? |
[2015-09-29 17:31:57] |
This is not relevant but what specific setting are you referring to: - I have "connect to trade service" set to "Yes" There is no command or setting with this exact name. For this problem, refer to the instructions here about Ignored Signals: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#IgnoredSignals Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-29 19:21:35
[2015-09-29 19:04:44] |
Apologies, I was referring to the "Send Orders To Trade Service" option in the Study Settings menu for the Spreadsheet System For Trading study that links my sheet to my chart.
[2015-10-01 02:04:19] |
OK, just let us know if you need more help. The information we linked to should help you resolve the problem.
