Date/Time: Thu, 02 May 2024 09:19:31 +0000
Chart Scaling
View Count: 790
[2015-09-28 13:14:41] |
User94740 - Posts: 333 |
SC, I am wondering about the functionality of the constant range scaling. If I take off the auto center function, then everything runs off my chart no matter what. The internal settings in this case, when deactivating the auto center function, should be configured to determine the high and low of the data present on the screen. If this is what is supposed to be happening, then it is failing. Screenshot uploaded:
SC enquiry Chart Scaling 20150928-1.docx - Attached On 2015-09-28 13:14:27 UTC - Size: 204.12 KB - 302 views |
[2015-09-29 04:34:42] |
Constant Range scaling is not designed to do this. It is only designed to keep the last bar within view. We are working on some documentation for this here: http://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#UsingConstRangeScale It will be ready in a couple of hours. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-29 11:51:39] |
if I remember correctly, sc had some time ago a function for compressing and decompressing vertically the chart. Is there a reason this was discontinued? PS I also notice when I change the analysis that the settings for the scaling are reset Date Time Of Last Edit: 2015-11-29 12:33:34
[2015-11-30 07:49:22] |
Refer to the documentation for Interactive Scale Range: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#InteractiveScalingExpandCompress This functionality has not been discontinued. PS I also notice when I change the analysis that the settings for the scaling are reset Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-30 07:50:29
[2015-11-30 11:53:42] |
the interactive scale range works nice, thx. The chart settings/scale is being reset whenever I change the analysis. It is only tpo chart relevant. I have tried with time and trade setting charts and it is ok, but the tpo analysis must cause any settings in the chart settings/scale to be reset. |
