Date/Time: Sun, 19 May 2024 16:25:48 +0000
Possible to overlay studies from a instance of sierra to a chart from another instance ?
View Count: 1205
[2015-09-28 09:37:10] |
sierra28 - Posts: 120 |
because having 2 connections: 1 for studies from futurs datafeed broker and another connection for trading with cfd broker. thanks |
[2015-09-28 17:43:44] |
Yes this is possible by sharing data between copies of Sierra Chart. This is documented on this page here: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#Sharing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-28 18:53:30] |
Thanks, its works fine !. last question: how to have the same parameters for each studie from source instance and copy instance: Should i have to configure manually each studie in copy instance or is there a quickly solution ? |
[2015-09-28 21:14:15] |
You have to do this manually.
[2015-09-29 12:30:50] |
i have shared data beetween copies of sierra and trades are ok, but in the capture i display data from futurs broker and trade with this dom cfd contracts. i don't understand why there is only the firt level of depth volume displayed (2 at bid and 3 at ask column) whereas i see the ten level on the left of this dom do you know why ? thanks |
Capture.JPG / V - Attached On 2015-09-29 12:29:45 UTC - Size: 157.94 KB - 329 views |
[2015-09-29 18:24:20] |
Not sure about this. Make sure the following settings are correct: Global Settings >> Chart DOM Settings >> Maximum Depth Levels Displayed is set to 50. Global Settings >> General Settings >> Use Non-Chart Data from Remote Instances is enabled Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-22 09:53:03] |
User7097040000 - Posts: 13 |
I'm missing something here. According to the heading of this thread "Possible to overlay studies from a instance of sierra to a chart from another instance ?" I can see that @Support provided a link to create the second instance and share data, but I don't see anywhere how to overlay studies into the second instance. @Sierra28 said it work, so there's information I don't get. Thanks for your help |
[2019-05-22 15:32:02] |
What you want to do is not supported.
