Date/Time: Sun, 19 May 2024 15:32:38 +0000
Cloud Visual Error
View Count: 766
[2015-09-26 05:11:28] |
esMike - Posts: 67 |
There is a slight problem with the code for fill and transparent fill... The graphics should change color at the point where the top and bottom fill cross each other, not the bar... It's coloring the top fill the color of the bottom fill before the top and bottom fills are inverted, and vice-versa. Date Time Of Last Edit: 2015-09-26 22:42:08
Private File |
