Date/Time: Sun, 19 May 2024 14:54:49 +0000
Order price line
View Count: 919
[2015-09-25 15:23:06] |
User742670 - Posts: 43 |
Hello, I haven't done any changes to my Sierra,but now when I enter the market and the position is filled the price line disappears... Why?How can I make it visible during the trade? Thanks |
sierra order line.jpg / V - Attached On 2015-09-25 15:23:03 UTC - Size: 766.06 KB - 297 views |
[2015-09-25 19:07:13] |
When posting an image, only use the method described here are no other: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Most likely there is a problem with the Position Average Price being calculated from the order fill data. So you need to clear the non-simulated Trade Activity Log data for the Symbol and Trade Account: https://www.sierrachart.com/index.php?page=doc/doc_TradeStatusWindows.html#HowAvgPricePositionsCalcUsed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-25 20:03:47] |
Specifically this is the documentation section to refer to: https://www.sierrachart.com/index.php?page=doc/doc_TradeStatusWindows.html#PositionLineNotVisible The previous section we referred to goes into a lot of background detail, but the link above is more short and specific to the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
