Date/Time: Thu, 23 May 2024 16:52:53 +0000
Trade Activity Log - commission
View Count: 1742
[2015-09-25 13:32:30] |
User68117 - Posts: 64 |
Hello, Please set as commission for the EUR / USD Trade Activity Log? If I set the tab Additional / Round Turn Commission on the $ 5, so I'm in the Trade Activity log shows a meaningless value to see the screen. Thank you for the advice |
commission 1.jpg / V - Attached On 2015-09-25 13:32:03 UTC - Size: 151.95 KB - 335 views commission 2.jpg / V - Attached On 2015-09-25 13:32:08 UTC - Size: 341.74 KB - 382 views Attachment Deleted. |
[2015-09-25 18:35:02] |
This is not going to work properly. That particular symbol is traded in a very large quantity. Making the actual commission very large. Unless you trade a consistent quantity with that symbol, setting a commission will not work properly. Refer to the documentation for the Round Turn Commission setting here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
