Date/Time: Sat, 18 May 2024 04:05:04 +0000
Export All Chart Data To Text File
View Count: 1150
[2015-09-25 12:07:46] |
User13863 - Posts: 10 |
Dear Support, Thanks for a great program. In a future version of SC would you consider allowing all study data on a chart to be exported when the "export bar data to txt file" or "export intraday data to txt file" feature is used instead of just the basic DateTime OHLC AV BV data? To be fair, currently I can put on spreadsheet on the chart and then copy and paste into a spreadsheet program but its decidedly less elegant and consumes a lot more resources. Regards; Gil |
[2015-09-25 18:37:49] |
We will see about this. But you can just save the Sheet within the Spreadsheet as a text file with File >> Save As without copying the data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-25 18:39:37
[2015-09-25 19:22:49] |
SC, Thanks for the quick reply, alerting me to the "File>>Save As" functionality and considering the feature request. I do want to note one drawback of the "File>>Save As" is that the output is not CSV-compatible. Obviously, an amateur programmer could make it work but I just wanted to make sure you guys knew that it still requires a bit of effort. Cheers; |
