Date/Time: Sat, 18 May 2024 12:03:34 +0000
missing vertical grid line before start of overnight sessions
View Count: 658
[2015-09-25 10:25:29] |
User65931 - Posts: 13 |
Hello, For an hourly grid setting, I've got a vertical grid line for 05:00am and then the next vertical grid line is for 07:00am on CLX5. What happened to the 06:00am vertical grid line that used to be almost next to the 07:00am? You can still see it now on the CLV5 contract. This line was useful to i) see the start of day when scrolling hundreds of hours, and ii) know when daylight savings times change |
[2015-09-25 18:46:23] |
Here is the documentation for the Vertical Grid: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#VerticalGridLinesAtEvery The issue has to do with the data in the chart and we cannot comment on this unless we can see it. You need to post an image of the chart showing the spot where you do not see the grid line, by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Increase the bar spacing in the chart to only show the relevant part so we can see it clearly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
