Date/Time: Sat, 18 May 2024 11:36:45 +0000
Triangle Tool Button - Issue
View Count: 648
[2015-09-25 09:51:53] |
sampater - Posts: 243 |
I added the Triangle Tool to the Control Bar and appeared a message in the Message Log: Cannot load control bar button image from location D:\SierraChart2\Graphics\Buttons\Button_766.bmp | 2015-09-25 11:42:13 *
Version 1299 |
[2015-09-25 10:00:04] |
This will be solved in the next release.
