Date/Time: Sat, 18 May 2024 06:00:21 +0000
Email Service
View Count: 1264
[2015-09-24 17:22:18] |
markuz - Posts: 90 |
Have you experienced an issue with Emailing Alerts using TMobile? This is from TMobile, but it's not working This is from their support. You can send messages to any email address. Each mobile number has its own email address in this format: your10digitmobilenumber@tmomail.net. Example: 6105551212@tmomail.net |
screen shot email sierra.bmp - Attached On 2015-09-24 17:22:09 UTC - Size: 1.91 MB - 349 views |
[2015-09-24 18:21:14] |
This is not unusual for the message to not be delivered. The T-Mobile server could be blocking it. We will check on this now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-24 22:50:59] |
Sierra Chart - Max - Posts: 5618 |
We are not blocking the tmomail.net domain. If you do not see the email, you will need to contact TMobile about why the message has not been received.
Sierra Chart Support Date Time Of Last Edit: 2015-09-25 04:59:59
[2015-10-01 09:51:39] |
What is the T-Mobile technical support number?
